-   -   Any Pontoons with Center Walkthrough? (https://www.winnipesaukee.com/forums/showthread.php?t=19863)
thinkxingu 09-20-2015 07:31 PM
Hi All,
Looking at upgrading our pontoon and trying to decide between rear changing room/storage/sun pad option vs. center walkthrough. The thing holding us up is storage for a cooler and the table being in the way if walking out the back. Size would be 200 series, so about 21'. Any thoughts welcome, including layout input. Thanks!
Dad sold the C * C 09-21-2015 06:09 AM
Our 23' Premire Sunsation has the changing room tuck under the front couch and is a straight shot through the center. There is storage under the changing room because it incorporates the backrest, though not as much as one under a sun deck. I'm sure others have this Option.
We like the layout because it has 4 doors and we can fit the kayaks in if we want to. It's good for the dogs because they can look out all 4 sides without getting up on the seats.
noreast 09-21-2015 12:57 PM
Many brands do put changing room in a front layback. We only keep the table in when were using it, it's always in the way. I believe all brands also make a center walk thru, If you mean 2 lounges to the side @ stern. Most will start at 22' though. I think people on here will tell you 22' is minimum for the lake anyway most would recommend 24'. That set up is usually called their sport model.
