-   -   Recommendation for concrete cutting contractor (https://www.winnipesaukee.com/forums/showthread.php?t=17776)
mountainhouse 06-27-2014 10:45 AM
Hi all;
New to the forum. We are buying a house near the lake in Meredith and wondered if anyone knows a good contractor, that can cut the poured concrete wall to add in a door and a few windows. This is done all the time with an ICS Diamond Blade Chain Saw.
Thanks.
jmen24 06-27-2014 11:25 AM
Originally Posted by mountainhouse (Post 227634)
Hi all;
Thanks.
L&S Concrete Cutting out of Loudon # 603-798-5300
The owners name is Stacy, tell him Jeremy sent you!
TheProfessor 06-29-2014 09:02 PM
Hi all;
Thanks.
Not sure but this may require more then a concrete cutter.
As mentioned above - those are the professionals that do cut concrete.
But may not be in the carpentry business.
All can get a tad complicated as the thickness of the concrete is probably not the thickness of the house wall.
You may need a general contractor. Or a good carpenter in addition to the professional concrete cutters.
And a side note. The concrete cutters are a tad messy with lots of concrete dust. Even with a built in vacuum.
mountainhouse 07-07-2014 01:27 PM
Thanks - L&S Concrete Cutting says they use the ICS wet saws, and the rest is basic header and door and window framing per the latest IBC 2012 code.
