-   -   Boat trailer inspection (https://www.winnipesaukee.com/forums/showthread.php?t=17107)
RDuffey656 02-07-2014 06:59 PM
Hi Understanding that the state law requires that all boat trailers over 3000 lbs gw are supposed to be inspected, I was just wondering:
does anyone actually have this done and if so who in the lakes region does it?
Bob
BroadHopper 02-07-2014 09:06 PM
New to me.
Are you talking about a trailer weighing over 3,000 lbs or are the trailer capacity over 3,000 lbs?
I do know that a trailer carrying 2,000 lbs or more requires trailer brakes but it is not enforced, except in commercial use.
WeirsBeachBoater 02-07-2014 10:13 PM
Trailer with a GVWR over 3000 is required to be inspected. Most automotive inspection stations can do this. Belknap tire in Laconia definitely does trailers.
Breakwater 02-08-2014 12:43 AM
Law Change last year...
CHAPTER 266
EQUIPMENT OF VEHICLES
Inspections
Section 266:1-b
266:1-b Inspection of Trailers, Exemptions. –
I. Notwithstanding any law or rule to the contrary, trailers of 10,000 pounds or less gross vehicle weight rating not used in interstate commerce shall be exempt from periodic vehicle inspection requirements, but shall be subject as other vehicles are to periodic roadside inspection by law enforcement officers to determine that they have the proper required and fully functional safety equipment.
II. The director may authorize properly qualified dealers holding utility dealer registrations to inspect trailers of more than 10,000 pounds gross vehicle weight, to determine whether they are fit to be driven, and to issue inspection stickers, under rules adopted for this purpose pursuant to RSA 541-A. This section shall not apply to full trailers as defined in RSA 259:37-a or semi-trailers as defined in RSA 259:98, and shall not prohibit other official inspection stations from inspecting trailers.
Source. 2013, 127:2, eff. Aug. 24, 2013.
RDuffey656 02-08-2014 10:27 AM
That is great..thank you so much, one less thing to worry about...
