Shore front stonework & landscaping
Does anyone have experience, good or bad, with landscape contractors in the Meredith or Moultonborough area that specialize in shore front stonework? I'm looking for someone who can not only build some stone walls and/or patios, but also help me through the permit process. Considering the layout of my property I'm guessing that most of the work would be to be done from a barge on the water.
Thanks, |
Permit process
The permit process will be a lengthy one. I think you should concentrate on getting the necessary permits before you consider a mason. The first thing I would do is go before the local wet lands and see who they recomend to help with the permit process.
recommendation for permiting
I would lookup Folsom Design in Meredith-they are great at getting things permited. They may also recommend stone wall people. 603-279-7477 Good Luck
Landscape Contractor
Give Chris at Miracle Farms at 603-253-9292
http://miraclefarmslandscaping.com/ He has an outstanding reputation and has completed many waterfront projects. |
thanks egatlake i also need lanscaping design in Moultonboro and will give them a call this summer
Thanks all for the contacts and advice. It looks as though I have my work cut out for me.
| All times are GMT -4. The time now is 06:05 AM. |
