Septic Pump Out In Wolfeboro
Been smelling sewage in the side yard of my house and thinking it may be time for a pump out. The previous owners never had it pumped out, but there were only two of them. There are two adults living in the house now.
Any recommendations on folks who pump out septic tanks in the Wolfeboro area? |
I use Lakes Region Septic. They are located in Brookfield.
Tel. # 603-522-6246 http://lakesregionseptic.com/index.html It would be good to locate the covers of your tank and have them exposed when the pumper arrives. If they have to locate and dig them up, it will probably cost you more. There should be a drawing/sketch of your septic system layout that was used when the house was built. If you don't have it, the Town might have a copy of it. If you are getting a smell, it might be that your leach field is plugged up and not draining well. |
If you are smelling septic gasses I would look for wet or soft spots in your lawn in the leach field area or at the tank.
Sometimes when a close by septic tank is pumped you can smell it in your yard. Maybe you neighbors was being pumped when you notice the smell. |
We use DJ Septic.
X2 on DJ's! He is a very good guy to deal with and has been very helpful to me in the past. He is very knowledgeable about the systems and what can go wrong.
http://djsseptic.net/ |
Thanks all. The sewer smell is not there today and I was told that sometimes if a neighbor has been pumped out you can smell that. Or if the wind is right you can sometimes smell the gases from your own pipe.
I didn't have the tank pumped out or inspected when I bought the house, but it's not that old. (2005) I was meaning to have it pumped out this summer, but it slipped my mind because I was enjoying sailing on the lake so much!! Anyway Lakes Region Septic came in about $30 less than DJs with no add-on costs. |
You should have a filter on the exit side of your tank and they will clean it for you. It might be a good idea to watch him do it so that you can do it yourself between each cleaning. Some people just can't do it but I think it's good insurance to keep the filter clean. I always clean my filter every year and have the tank pumped every three years. I have one of those plastic green risers that goes on top of the hole at the exit end. It sticks above the ground and all you have to do is take a few screws out to remove the cover. http://residentexpert.com/files/2011..._Riser_Lid.jpg |
Lamprey septic
Scott from lamprey septic inspected our system during our home inspection and noticed a fitting that needed to be replaced. He said he would come back in the spring to do it when all the snow cleared, and sure enough he did. I had no commitment to him other than the home inspection but after he did that I didn't even consider another company. I pump out every fall no matter what. Any harm in this? I thought a septic inspection was automatic when buying a home. I forgot your process and whether a real estate agent was involved.
Hmmm, I thought NH required a septic inspection before title is passed, or is that just for waterfront?
I guess the rule only applies if your property line is within 200 feet of water. Anyway, you should get it pumped and checked out, trust me, they fail at the worst possible time (think sewage fountain). My pump failed on Memorial day weekend many years ago with about 15 people in the house, fortunately it made noise before it got to the fountain stage. Scott Lamprey came by and pumped it out, saving the weekend. Having it fail in the middle of the winter with 4 feet of snow on the ground would really stink (pun intended).
pump out or not...
Either way, don't forget the Rid-X.
I have mine pumped out every spring which may be overkill. It only costs $200 but gives me a peace of mind.
I got mine inspected at the inspection. They ran all the faucets at full blast and watched how long it took to drop in the tank. Mine came up perfect. I get mine pumped every three years as well. Only two in my house as also. Well, I have two cats too, but they are not toilet trained.:laugh:
Thanks for the render though. I have to get this done before the snow flys... |
Septic Smell
Bye Bye
Al's Laconia Septic Tank Service, telephone 524-4777, is a one truck, owner-operator business, and Al drives the truck and does the work of pumping etc; he charged me $190 to pump out a 750-gal tank after first telling me that it would probably cost about $225 over the phone. That's probably because most distribution tanks installed since about 1980 are usually 1000-gal, and go for the $225 pump-out price.
As already mentioned earlier in another thread, Lamprey Septic in Moultonborough told me it would cost $1500-1800 to replace a septic pump and the check valve and about 4' of pvc pipe and fittings inside the smaller remote tank at the bottom of the hill. Going to Lowe's Home Improvement in Gilford, an identical pump can be purchased for $225, if you want to do that yourself........and "never stop improving!" .... :rolleye2::banana: |
After many years of being involved with septic pumps..you CAN NOT purchase the same pump at Lowe's that Lamprey Septic will install for you. Lowe's doesn't even guarantee them when Lamprey always does! Not to mention you always get what you pay for!
One model, the smaller model, sells for about $175 if I remember correct, and comes with a one year warrantee. The larger model which was probably a 110volt-1/2-hp septic pump with a teather switch included sold for aprox $227., and it comes with a lifetime warrantee. This $227 Lowe's septic pump was the same similar style, size, appearance, voltage, 1/2-hp, and included teather switch as what Lamprey Septic was talking about when he said to me it would cost about $1500 to $1700 to replace the pump and the in-line check valve and about 48" of 1 1/2" white pvc pipe and pvc fittings. Plus, the Lowe's pump comes with a lifetime warrantee to the purchaser, plus if you have ever needed to return an item to the Gilford Lowe's, then you know that they are easy. Plus, Gilford Lowe's also offers free coffee in stylish styrafoam cups, all day long..... |
If you have a problem with a pump at Lowes in Gilford they tell you to call the MFG. Maybe returns are easy in other area's but not pumps. Sure you can get the same spec's, ie - 1/2 hp ect. but not the same pump by a long shot. Not the same MFG or Model #. The pumps a professional installs are not available at Lowes or HD. BTW - Lowes switches pump brands about every second year, I think this is further to avoid returns.
Furthermore, I'd wager a bet that most of the pumps(different brand same HP) at Lowes cost less than what Lamprey pays for his reputable brand. |
About three or four years ago, I purchased three of the 1/6 hp, aprox $68. pumps from Gilford Lowes, and used them for January, February and March as water-circulators to keep my dock ice free. In late March, just short of three months from date of purchase, I was able to clean up two of the pumps and return them in their original boxes for a full refund at the Gilford store. It was a fast, simple and easy return transaction.
Do I feel a little bit guilty about doing that? Yes, I do, but now I would definately buy another pump from Lowes, plus the two pumps which I returned seemed to be in excellent working condition despite having been used off and on for almost three months. Probably, someone else bought them later on after my return thinking they were new too because they looked like new. How's about that! ...say hey.....we are all sinners......some of us just get caught a lot more than the others! |
Less
Its customers like you that causes the prices on products that we buy to rise in price to recover the loss to the retailer. when an item is returned to a retail store they have to be refurbished and marked down in price as used. Shame on you thats dishonest :( |
Tell me that is a joke, that you did not really do that!!!!! If you did, I think that is disgusting. I used to think your posts were funny, but that is just plain dishonest if that is true.
I think I know why. :eek2: |
:eek: |
....oh come on.....you guys cannot be for real......everybody probably does that type of merchandise return thing with big box store-return policies being so easy....it encourages someone to use an item for 89-days and then to return it on the 90th or something close to this scenario......you know it.......I know it.......the big box store employees know it.....and the big box stores; ....walmart-lowes-homedepot-kohls-tjmaxx-marshalls-& others put to work because it is a business builder....it encourages customers to buy because they know their purchases can be returned EASY......
......and besides all that......we are all guilty of being sinners but some of us just get caught more frequently than others! ....so you all can just get off of your very well-groomed and manicured high horses, and let's get back to the topic of this thread......whatever the heck that was! |
:laugh: |
...thankyou very much!
You know that the Gilford Lowe's easy returns was one big reason why I continually return there to buy more stuff. While driving there to Lowe's, I have no problem driving right past Heath's, Aubuchon's or Laconia Servistar.
Do I feel a little bit guilty about my use and return.....maybe a wee small bit....but now partially because of their easy returns I justautomatically head for Lowe's Gilford. As a matter of FACT, my car knows the route to Lowe's all by itself, so I just lay back and take a short snooze for the ride over to Lowe's. ......thankyou very much & good knight!!! |
These returns cost the rest of us money...
Part of the cost determination in retail is the cost of handling returns. In some cases, a supplier puts a 25% (could be higher, could be lower) obsolesence fee...If a unit costs the company $100, and that unit is returned to the company and then returned to the manufacturer, the company is not reimbursed $100, they are reimbursed $75. This shortfall is built into the cost we as consumers pay for goods.
When the Rochester Fair would open in the fall, we saw a spike in the sale of small Multifunction machines, printer-fax-copier-scanners. We looked good on the sale, because we would easily sell the machine and some extra ink, normally just the black cartridge. The sale would take place on the Thurs or Fri as the Fair opened. Fair is open for two weekends with the week in between. Guess what we would see on the Mon after the fair closed, sometimes on the Sun night it closed? You guessed it...the machine would come back along with any unopened ink, usually without the box for the unit. FLL, you can put your head in the sand, or justify what you do by saying others do the exact same thing. Well, sorry for you...I do know that I can live my life with my head held high knowing that I would never take advantage of a company's return policy. In my humble opinion, your attitude in this behavior puts you in a position in the respect ladder of having to look up to see down. :( |
....with all due respect ...
...you know....with all due repect to everyones sense of what is right and what is wrong here....my two item return was totally within the store's return policy....and was transacted in about 60-seconds, one morning in early April, 2008 or sometime, and the lady employee did not bat an eye or hesitate at all to make the return transaction...
...I had the original receipt....I ALWAYS save the original receipt....the two pumps looked and still worked like they were brand new.....and the two pump boxes were also in like new condition....and the receipt quickly proved it by passing the return rules scrutiny of the upc code scanner... ...If Judge Judy were working that April morning at the Lowe's returns dept in the Gilford Lowes....you know what she would have said to me.....Judge Judy would have said to me .... "thankyou much much for shopping the Gilford Lowe's and you have a nice day, you good looking, tall, thin, handsome man you!" .. ;):D |
"Pump-outs" should be done more frequently when your residence has dishwashers, clothes-washers and garbage disposals—or even if a few incorrect paper products have entered the system. :eek2: A gently-used septic system with a healthy and root-free drainfield can go decades between pump-outs. |
FLL, does that make you feel more like shopping at Lowe's thinking that you may be getting used products? Apparently it doesn't bother you. I certainly understand if you buy something and it is broken or isn't what you thought and you return it IN A REASONABLE TIME FRAME, but to intentionally use something for three months and then return it is just theft. I am not one to get on my "high horse" because no one is perfect but what you did is just wrong.
We hope you love what you ordered, but if something isn't right, let us know. We're happy to exchange your item or refund your money. You can return your order at any Lowe's store for your added convenience. Our ultimate goal is for you to be completely satisfied with your purchase from Lowe's. If you receive an item you're dissatisfied with, you may return it within 90 days** to any Lowe's store for a refund or exchange within our current return policy guidelines. For additional assistance, visit your local Lowe's store or call toll-free 1-800-44-LOWES (56937) and one of our customer service representatives will be glad to recommend alternate return options that may be available. Information contained on the invoice will be necessary to process the return or refund. Please have the invoice ready when you call. After the return period,** products will be covered by the manufacturer's warranty as applicable. **30 Days for Outdoor Power Equipment and Major Appliances Outdoor power equipment purchases and major appliance purchases may be returned within 30 days of the date of purchase, with the original receipt. Outdoor power equipment includes mowers, chain saws, generators, pressure washers and more. Major appliances include refrigerators 9 cubic feet or larger, washing machines, dryers, range hoods and more. Lowe's will repair it, replace it or refund the purchase price based on the original method of payment. Products must be in like-new condition in order to receive a refund. Items still covered by the manufacturer's warranty will be repaired at no cost to the customer. Repairs not covered under the warranty are the responsibility of the customer. For manufacturer defects, please call Lowe's Service Advantage hotline toll-free at 1-888-77-LOWES (56937) to set up a factory-certified service appointment in your home or for any general assistance. |
I apologize for participating in the hijacking of this thread. Some things frost my a$$ so bad that I felt compelled to post.
....& don't forget to save your receipt, baby-cakes!
....ok....so I was back at the Gilford -Lowe's yesterday picking up some heat-shrink weather plastic and some 12' pvc molding to do a little heat loss prevention on some of my huge drafty windows with the killer-diller views that look out to the lake, Gilford and Gunstock Mountain.......yuo know....trying to save some money on the expensive propane bills....so I took another look-see at the two septic pumps there.....and the big one actually costs $277, and not the $227 as I said earlier. It is 1/2hp-110v-teather switch included-unlimited warranty.
The key to making the return warranty work is to hang onto the receipt. You know Lowes' does not get into the pump being broken, it just says that it can be returned. You know, after using them for almost three months, and no longer having any more need due to the warmer temps of April, I probably thought to myself......well....let's go see if they are returnable....because 2 x 68=132 and $132 will buy a lot of groceries at the Plymouth Walmart. Lowe's must have 100's of thousands of customer experience every year at all their stores, and they make their return policy what it is to help to power up their business. And, their easy returns policy has definately been a factor to get me to be a regular Lowe's customer. Their easy returns is a biz-promo plan and it worked for me........and besides that I did not creat any theft....any misrepresentation.....any deception....or any anything....I made the returns within the rules of their return dept....and used the money for groceries or gas or something. The #1 rule that everyone should be getting from this thread is to save your receipt! |
Just fooling yourself....
My guess is that all those local hardware stores you drive by to go to Lowe's all asked you not to return. I'm out. |
Please do not feed this troll anymore people.
1 Attachment(s)
Our camp has never been pumped and may never need to be as it is mainly used during the winter. I have had it open to fix clogs from grass roots and there are almost no solids in it at all which means it is working great doing it's job. |
FLL What a leach you are. Type of person that creates the problems we have in the world now. I hope you get your due someday. And I hope to god you didn't ever have kids.
Makes sense
FLL no matter how much you try to justify your comments I think you lost (if you had any) all respect any members of this forum had for you or your comments. |
By using the two $68-dollar pumps for aproximately 89 days and then having the Lowe's return dept accept them back for full refund was a business-promoting decision made by Lowe's. They know there are some people who will take advantage or abuse their returns policy but they have it in place because they feel it increases their over-all business and has proven to be a potent piece of retail-ammo in their Lowe's business plan. And, furthermore, while returning home to Massachusetts to USE that tax-free refrigerator without remitting the sales & use tax due to Massachusetts Dept of Revenue is in fact a violation of Massachusetts law; the returning of my two small pumps was indeed part of a purchase and return that both sides, Lowe's and myself were willing to do, and was not a violation of any New Hampshire law. So, what does this Forum court of opinion have to sayeth about my argument? And yes, I am wearing my hockey goalies equipment including facemask, chest protector, shinpads and big fat goalie stick so you can let your comments fly! |
Less, let me try to explain to you what your justification sounds like to others.
Less argument paraphrased: I behaved badly, but there are people in Massachusetts who also behave badly. Let me tell you, I behaved badly but there is no law against what I did, indeed, Lowe's knows people like me will behave badly so they increase their price accordingly to account for my misdeed since they need to make a profit. Others are paying the price for my bad behavior, but that is ok, since I got away with bad behavior. Now those people in Massachusetts behaving badly are actually breaking the law. So since my bad behavior isn't outlawed, yet, I am perfectly justified stealing from Lowe's, I found a loophole that allows me to behave badly, you should be congratulating me on my bad example and my willingness to let others pull my weight for me. You should praise my ends justifies the means mentality and not admonishing me for my bad behavior. |
I enjoy reading his posts and don't really care if he returns items after using them. That's between him and the store. He is a good sport about everthing and I have never seen in any of his posts where he attacks people because of what they say or do. Don't go away FLL.:( |
Sorry to hear you feel that way rusty. If you don't care that he he sees no wrong in what he does, you are not different than him.
Fll fyi
Granted there is nothing they can do but maybe they can reference the message and figure out who you are and watch out for you in the future. What you did was wrong and makes you worse then a thief. You try to be funny and we brush it off and sometimes you are, amusing, but most of the time your just an (insert comment). What you did was something most would expect from white trash so I guess we know what side of the street you come from! |
John 8:7
"Let him who is without sin cast the first stone"... |
Character
Character is much easier kept than recovered.
Thomas Paine |
Sometimes when I close my eyes, I can't see.
Anonymous |
If we followed this lesson it wouldn't be much fun around here! |
....easy returns at Lowe's!
......ok.....sure .....there's always a few rotten apples around that can spoil the whole box.....and if too many Lowe's customers went the 89-day free rental route.....then Lowe's would probably tighten up their returns policy....so....Lowe's probably goes with their easy returns dept because they consider it to be a business builder...one good reason their customers come back to make the next purchase is it can be returned; easy!
......just look at me...since making that not-too-honest return of the two 1/6-hp utility pumps....I have since purchased a number a bigger items like a snowblower, pressure washer, refigerator, kitchen stove, paint, masonry blocks, cement, perennial plants & flowers, landscape timbers, top soil & mulch....and other items.... ......and what did I do with the return money from the two pumps about four years ago....I probably needed the money for groceries and gasoline....a lot more than I needed the two pumps at the time......so they got returned.....thankyou very much Gilford-Lowe's! .. ;) |
Less, Less, Less, I hope you have a Merry Christmas and a Happy New Year!!!
And to think this all started by CateP asking about septic tank service. CateP, hope some of this thread helped.
Couldn't help it :eek: |
Hummm!
Did I not see Belmont resident say that SHE doesn't pay to swim!
$55 @ month! -------------------------------------------------------------------------------- FLL, i thought you were thrifty? You can join LASC for less than that! I am a PSC alumni so I get to use the iniversity pool free! One of the resort at WV has a heated pool. I have used that pool many time without paying. The staff doesn't pay much attention. __________________ The U.S. Constitution doesn't guarantee happiness, only the pursuit of it. You have to catch up with it yourself - Benjamin Franklin |
| All times are GMT -4. The time now is 09:29 AM. |
