-   -   high performance diesel shop (https://www.winnipesaukee.com/forums/showthread.php?t=13308)
jims 11-18-2011 04:56 PM
looking to have some work done on a 2003 ford deisel engine ,any high performance deisel shops in the lakes region or so nh, ma
ishoot308 11-18-2011 05:20 PM
Finding a good private non dealer diesel repair shop is very hard these days. The one place I can recommend is in Weare, NH and is called "Diesel Dons Truck Service" 603-529-1777. My company used them when we tried out diesel vans and pickups as company vehicles a few years ago. They were pretty decent.
Good Luck!
WeirsBeachBoater 11-18-2011 05:46 PM
Call Craig at CFO in Meredith, I know he has a hot rod Duramax. 603-279-9059
Belmont Resident 11-18-2011 06:12 PM
What do you need done.
I use Winnipesaukee truck for all my deisel needs.
jims 11-18-2011 07:01 PM
rebuild top end
looking to correct engine design flaws , delete egr system ,replace head bolts with studs ,replace oil cooler ,new head gaskets ,install new turbo ,air intake $2300 in parts +labor
VitaBene 11-18-2011 08:30 PM
Call Larson's Diesel Performance. He works with his grandfather at Larson's Automotive on Airport Road in Moultonborough.
I was able to google and find them on Facebook
HomeWood 11-19-2011 01:52 AM
All good things to do on a 6.0 liter Powerstroke.
Belmont Resident 11-19-2011 06:18 AM
2300?
I need to have all my injectors replaced, possibly the injector control module and a new turbo. The cost for injectors is $2300, new turbo $1000 and if needed control module $750.
I was going to buy a new one but I’ll be damned if I’m going to give Ford any more money. I’ll pay someone else to fix the problems.
jims 11-19-2011 09:42 AM
repair parts costs
i priced out some top end rebuild kits from some online deisel shops and found the pricing was better in kit and package form .(www.pure deiselpower.com)they have two top end rebuild kits one at $1349 one at $1849 , turbos starting at $1000 .this is for my work truck , i hope i dont have to replace the injectors $$$$$$$$$ .i might get a programmer and do a new air intake if all goes well with the repairs .
robbsracingengines 11-19-2011 10:04 AM
Theres a guy here in the Nashua area that is a mad scientist with the Ford diesels. His name is Johnny K. He is well known in this area as the go to diesel guy. Pm me for his number if you want it.
BroadHopper 11-19-2011 12:40 PM
Guy from Mass.
There was a guy from Mass. who had a high performance boat with twin diesels. He owns a diesel shop in Mass and repairs big rigs as well as small. The two diesels in his boats were his passion and the boat sings like the 4 strokes. He was able to hit 80 mph in half the rpm as the 4 strokes! The motors diesel smell is very faint with no smoke!
He was telling me he can double the torque of any factory motor with few hardware modifications and a 'shot' at the ecu. It doesn't take much as the factory worries about reliability during the warrantee period.
Unfortunately I haven't seen him since the law was passed. =(
Belmont Resident 11-19-2011 10:33 PM
mine is a work truck also
I had injector problems from the get go but Ford said all was well until they finally died completely.
I hope Ford finally got it right with the new motor.
It’s sad when you pay so much for a truck that has soooo many problems out of the box. I guess like everything else the rush to get something new into production far surpasses proper testing.
I’m considering a business loan for the injectors and possibly a cold air intake and exhaust down the road. I’ve heard that combination with a chip can produce up to 22mpg.
How are your cab corners holding up? No shielding so they hold all the road grim and tend to rot. And the wheel wells are stuffed with foam which does the same thing.
Both are problems areas on mine. A fellow contractor cut the shield out of the wheel well and welded on stabilizers then undercoated the whole thing.
Anyways good luck with your upgrades.
Silverdale 11-20-2011 06:04 AM
We like Greg Ward's Truck and Equipment Repair in Alton, N.H.
603-387-2853. Many years experience and reasonable rates.
jims 11-20-2011 08:54 AM
a long list of problems
:(my 2004 f-350 ran great the first year , then all the problems surfaced , the brake system just fell apart (poor steel quality ) ,oil pan rotted out , fuel water seperator rotted out ,transmission lines rotted out ,new egr valve ,frame and subframe rot ,constant check engine light ,turbo problems ,i cant afford a new truck so im stuck fixing this one,
Belmont Resident 11-20-2011 08:00 PM
Wow, and I thought I had it bad.
How are your headlights? Mine are beyond pitiful and I’m looking for alternatives.
I went to the link you sent and saw a conversion to the Harley Davidson lights for the 04 Super Duty. I run 2 100watt aircraft lights that help a lot when driving in North Country.
I’ve replaced my front brakes twice and rears once in 115K. I’m running Raybestos parts and they seem to work great. The first time around I ran NAPA premium and they didn’t hold up well. Neither did the NAPA batteries. They only lasted 1 year. Now I’ve got Sears Platinum and they are excellent, but for $200 a pop they better be.
SAMIAM 11-21-2011 09:02 AM
Same with me, Jims...I thought I was safe with the optional factory warranty on my my 2005 Dodge 2500 .....but they just said "tough luck" the warranty doesn't cover corrosion. Oil pan, tranny lines, ps lines, pumps etc...cost over 5k.
Stay away from Dodge trucks.
Belmont Resident 11-22-2011 06:35 AM
Dodge
I mentioned to a friend that I was looking into how Dodge trucks have come in the last few years.
He said, you buy a Dodge and I will no longer be your friend. Of course he was joking, but serious also. With all the bad publicity and quality issues, Dodge has a long way to go before they are taken seriously.
I do know some who have had good luck with them and still buy them, but not one of them uses their truck for more than transportation.
They all have their issues but I thought the whole rotting out thing was in the past.
Why does Ford line the wheel wells with foam? Why design the cab corners to be open areas where dirt can gather and promote rot?
The 04 Xterra that I drive around because it wasn’t worth anything to trade in has 115K on it. No rot, little rust and it just keeps going and going.
My wife loves her Hyundai Santa Fe. Great price, great fuel economy comfortable ride, and they are not American made, so it probably will not rot out. What more could you ask for?
SIKSUKR 11-22-2011 09:35 AM
Geez, the guy just asked for a good diesel shop. I'll second Diesel Don in weare. I need to go lay on the couch now and speak with my therapist.:laugh:
Wolfeboro_Baja 11-23-2011 11:02 AM
Two words.......planned obsolescence (OR poor engineering!)!! :rolleye2:
I know because I have a 2001 F250 that I bought new that currently has rotting crossmembers on the pickup bed, plus the cab corners and door bottoms (all 4) need repair. I won't even get into the mechanical issues I've had with this truck. It's ridiculous some of the stuff I've had to repair or replace on this truck and it's only got 66,400 miles on it! :eek:
jst_4_kiks 12-07-2011 01:53 AM
If you are still in need of a good local diesel shop contact Shawn or Wes at No Limits Motorsports. Located on rte 107 by the Laconia Ice Arena 6035278119 www.nolimitsnh.com
Belmont Resident 12-07-2011 08:37 PM
no limits
I’d be leery of them. Wes used to work at Belknap tire. His customer service skills were terrible. Very poor attitude and did not like to be questioned about how much things cost, and would reluctantly give you a breakdown of service provided.
I took 3 vehicles worth of tires, inspections and repairs and went elsewhere.
I’ve never had dealings with the other Shawn.
nhhick 12-09-2011 02:12 PM
We've had good luck
Between my dad and I we have had 4 Dodge trucks since 2001. The 2 that have been traded in have had well over 100K on them and no issues except for normal wear (brakes, CV joints, etc), and the were not just for commuting but for towing, farming, and forestry work. My Dad tought me to take care of my truck and it will take care of you and it has prooven true since I started driving.
As far as the Ford issues check the diesel forums as there are a lot of good advice on them from people whoe have had the same issues. As someone who went to school for deisel technology (agricultural) its no surpise there's are a lot of issues with the new engines, across the board. emissions standards change fast and by large steps and do not leave enough time to properly test everything. Wish we could go back to the bullet proof 5.9 Cummins and 7.3 Powerstokes.
Belmont Resident 12-09-2011 06:10 PM
Service
I’ve always spared no expense in taking care of every vehicle I’ve owned. Regular oil changes with Amsoil, filters changed grease, etc. It’s the things I have no control over that fail. Things that for a diesel truck should be built to compliment the engines life expectancy are what are killing me.
FYI I know a die hard Ford owner that stopped in to test drive a Tundra and bought one.
I asked why he said the ride and fit & finish sold him on it. His truck was only a 150 but fairly new.
robmac 12-10-2011 04:01 PM
Alot can be said about Toyota p/u trucks but riddle me this. Why is it everyday the Toyota dealers get delivery of p/u truck frames?
gtxrider 12-12-2011 09:55 AM
Rust
There was a trouble with frames rusting through on the small Toyoyta pickups
robmac 12-12-2011 08:06 PM
these are full size frames they get m-f every week,I laugh as I watch them unload every day
Winnisquamguy 12-13-2011 08:33 AM
If I remember correctly didn't Toyota buy back all the trucks with rust and gave them double what the NADA was on them?
Belmont Resident 12-13-2011 01:53 PM
Winnipesaukee truck
This is another reason why I like these guys. They diagnosed my diesel truck problems and before ordering the new parts they installed known good used parts and tested to see if all the codes cleared.
That is going the extra mile, something you do not see often with auto repair shops
Rob Toyota had a problem with frames on the 2005 line of Tundra’s.
Me I would not buy a Toyota Tundra because the fuel economy is terrible.
Also I personally think it is a rather boring looking truck with no lines at all.
