-   -   Dock extension (https://www.winnipesaukee.com/forums/showthread.php?t=12811)
SAMIAM 08-11-2011 12:24 PM
Dock extension
I have a 6' X 6' rock crib directly in front of my dock and would like to extend my 30' dock over it......wondering if I'll need a permit, since nothing will be touching the water and it will be only a deck on top of the rocks. Don't want start the process if I don't have to. It will start with local building inspector. wetlands, the ERA and probably the NAACP and the UAW before I'm done.
Any suggestions?
TOAD 08-11-2011 12:54 PM
Any suggestions?
Don't forget Homeland Security and OSHA! :D
Onshore 08-11-2011 02:02 PM
If there has been dock surface extending out over that crib within the last 5 years then you could replace it without a permit from Wetlands. If not, you would need a Wetlands permit for the extension. The good news is that you should not need an individual permit from the Army Corp of Engineers. The State Programmatic General Permit from the Corps should cover it.
dayvsea 09-06-2011 08:15 PM
The old adage was you could not build OUT..This sounds OK as you are Grandfathered in, as it were....
SAMIAM 09-07-2011 09:34 AM
Think I'll take a chance and put it in........I'll bolt it to the existing dock, that way if they make me remove it, it will be an easy job.
tis 09-07-2011 01:51 PM
If there was not a dock there before, I don't think you can do it without a permit. When the permits for docks first came about we built a dock that was totally on shore parallel to the lake. We had no idea we needed a permit. we got a cease and desist order and couldn't continue until we got a permit.
songkrai 09-07-2011 03:21 PM
The state takes arial photos of all. How much they enforce such is unknown.
SAMIAM 09-07-2011 06:56 PM
You could be right, Tis......only thing is, nothing is touching the water. I would be building a deck on top of a rock crib. Will definitely check it out though.....don't want to run afoul of the law.
tis 09-07-2011 07:00 PM
That's exactly what we had. It was on rock and nothing touched the water.
Rattlesnake Guy 09-07-2011 08:15 PM
If it helps answer your question, I had to get the root canal, I mean DES permit to build stairs up the hill to the house. It was not over water. Fortunately I passed the endangered species impact study section with flying colors.
Winnisquamguy 09-07-2011 08:58 PM
Life is to short to worry about everything, play dumb!
codeman671 09-07-2011 09:43 PM
Great idea, especially when a Poster in this thread works for DES... :rolleye2:
garysanfran 09-07-2011 10:25 PM
Build with very old boards...
and definitely get some used nails!
DeniseW 09-08-2011 03:44 PM
I could see there being some argument over who owns the land you built on. Is the rock crib touching the shore or is it isolated in the water? Do you have pictures of it? I wouldn't think it would be a problem if it's a slight extension of your existing dock but you never know.
Denise - need a Boston handyman for some projects on my house
LIforrelaxin 09-08-2011 03:52 PM
I would be less worried about the exposure from this thread, and more worried about what the neighbors are like...... If you think your neighbors are likely to be upset by your expansion you are best to make sure you are all set from the DES, and local codes perspective... I thank God that I have a season dock, and don't have to worry about all these things....
