Your septic "is what it is"--if your lot is too small for a 4 BR septic, a diligent buyer will uncover your problem regardless of the system itself. This was the case for me--the system was sound, but the lot was too small for a 4 BR septic to be designated for 4 BR. The required lot size is subject to multiple constraints that are too complex for an amateur So I would just go with the best septic and the best well that I could, without regard for designation. |
OK- next size up! Like others, it's just the two of us full-time. Reading other threads on this forum made us change from three year cleaning to five year cleaning. I admit, waiting for Spring (the first five-year clean) started to make me a bit nervous. Butt- All's well! |
The cleaning and inspection was fine but every 5 years is what I will do from here on in. My system is also 35 years old. If I ever decide to sell I will deal with the septic testing at that time but I've had no issues so far. What I was told is it's not a bedroom unless it has a closet, not sure if that's legally true. When I bought the place the room on the first floor was called an office because it had no closet. Then I finished the attic over the garage, into what I call a bunk room, which also has no closet. |
The wording is, that if your septic fails, the state *might* only grant a 2 bedroom rated septic. But chances are if it had a reasonable 3-4 bedroom septic they would allow replacing it. As mentioned above, lots of waivers are granted. Like for like systems granted etc. all the time. It all gets fuzzy too that you might even be allowed to (re)build a 3 bedroom with a 2 bedroom septic. Or just build a 2 bedroom with a den that has closets and a bathroom. And never have an issue. My biggest concern is resale. Because it has this ugly comment of only 125 gal/day limit which equates to a 1 bedroom. It makes no sense to me why the septic was rated down to 125 because a of a properly installed (town approved and sleeved) well. Well company basically said “you should be good, we do things right”. So your drill guy will say you are fine. We might be overreacting on these technical labels. |
Your lot size and how much it covered has a lot to do with the gallon / day rating. But the assessment specifically calls out the new well as being the reason why they rated it as 1/3 the capacity it was rated for. I think what they might be doing is subtracting the area occupied by the well from the acreage to calculate how much septic flow the property can support. Regardless of where the well is legally located. |
Independent of locations and set backs.
I’m curious how large a lot has to be to support: A well (with entire 75ft radius) within property boundaries. A home (say 40x40ft foot print) A 2 car garage A deck/screen porch A driveway (maybe) A walk way (maybe) A 3-4 bedroom septic I bet it comes to .75 acres or more. Anything below 0.50 acres will probably need exceptions granted. Even though not every square inch of a property can be used for some things I think it all still counts on total acreage. Maybe only any wetland might also be subtracted. |
When we built on Winnipesaukee in 2012, we were able to construct a 2,600 finished square foot two story home with a full unfinished basement on a lot of .41 acres in size with a new well and a new three bedroom septic system with an attached 2 car garage, with decks, glassed and screen in porch, paved driveway and some walkways. Because we did not want a "Box", the footprint of house is irregular with lots of angles. No variances, exceptions or waivers, but our well 75 foot radius does extend onto the abutting property and we had to sign and have recorded an acknowledgement of that fact. Our engineer, architect, septic designer and well person were comfortable with the well radius issue. Given the topography of the abutting lot, it is unlikely in the extreme that the abutter could or would put a septic within that portion of the well radius extending onto that lot. I will say that it was a somewhat tight fit with the side setbacks, such that our engineer was out three times to measure and locate the foundation (excavation, footings and frost walls) so there were no surprises later on and then an as built. Well location came down to the practical issue of where the drilling rig could reasonably get to.
You can build a pretty good sized house on a half acre. You might have to move the well etc. but it can be done as long as the soil supports a septic system. You need to get somebody who really knows what they are doing to figure it out for you. Unless it is grandfathered you have to be 50ft. from the lake and need to leave part of the land untouched. In any event it can be done, but bottom line is you need a good professional to get the most out of the lot.
At one point we bought a half acre lot that had an existing 4 bedroom septic. If we remodeled the (two) little houses we didn't need a new septic but we wanted to put a new septic in because it was old and by doing so we were reduced to 2. I'm not sure why but it wasn't a big deal to us. But I do know people who have 3 on a half acre. |
I’ve seen buyers run from septic assessment that wasn’t as bad. |
Radon Needed?
And that would severely lower its value to me or future owners. Property was over $1.2m Bottom line is that size lot is over constrained wether you have a well on it or not. You either compromise on using lake water or limited official septic capacity. I thought it was just enough that you wouldn’t need any special waivers or grants to make it what we want or future owners might want (staying within grand fathered footprints and capacities). But it’s more impaired than I thought for the money. My guess is we could do what we wanted and everything would be granted. And it would hold its value and what we put into it. But if we decided to keep it as is use it for 5-10 years and then sell. It might not increase in value as much as a home without these constraints. And it’s not guaranteed we could do what we wanted either. It’s to risky. We bought in 2003 for $685k and sold for $1.025m in 2020. It could never have a garage and has a similar constrained septic. I thought it was all due to setbacks from the water. Ours was a long strip along the water. But I’m learning it’s about acreage too. I didn’t realize a Well uses up acreage. I don’t want to make that mistake again. I already know I’m probably buying at a peak (I’m ok with that). But I want to get something that will grow at a decent rate when the market does recover after the bubble bursts. I don’t regret buying the place in 2003. Not trying to make a killing either. I just don’t want to be behind the curve again. |
...... cheap domestic water!
It comes in a large cardboard box and the only item not included is the foot valve. Installation is just inches below the surface of the ground and threading it through a 2" pvc pipe under the rocky embankment, so it's a do-it-yourself type of an install. For a high quality, low priced, shallow well pump, 1/2-hp, 30-gal tank and pressure switch, go to www.harborfreight.com Drawing water from a drilled well is no guarantee it will be quality drinking water, and you can get quality Laconia town water for 25-cents/gal from the machine at the Gilford Hannaford. Like, how much faucet water do you actually drink or use for cooking, anyway? |
Yes, it seems like a money pit. I would run very fast from this one, especially at $1.2 million for a seasonal camp.
Something that I also find very curious is that you mention there is not even one closet in the entire house . It almost seems to me like they did it on purpose because of the septic issue. |
Meanwhile, in New York City...
An outlier--a few houses over--lives year-round on this desolate island (that isn't really an island). ;) Yesterday, via postcard, a realtor really-really-really wants to buy my place. (Postmarked=Arizona). :rolleye2: |
When we were in the market 5-6 years ago, just for example--There was the house I described before with 2.5 beds of septic for $1.3MM, and there was a $1.7MM teardown on land that was good but not great. |
A camp just came on today in Meredith 1.25 acres 200 ft WF 965K.
2 side by camps for sale in Meredith
The 2 adjoining camps have been in the family for 50 years, one priced in the $800s and the other in the 900s. Taxes on each over $10k. I bet they’ll both be under contract shortly despite their limitations. Crazy market!
#43 and #45 Happy Homes Rd., Meredith |
How can you not be happy with a name like Happy Homes Rd?😂
Probably, a speculative home builder will purchase the waterfront lot or lots on Happy Home Rd via a construction loan, tear down the old cabin, build a new, large, modern house, and then list it up for sale.
This is what's been happening lately in this area of Meredith neck. Have you seen the new house under construction at the cottage formerly named "gypsy camp", just before the Cattle Landing parking lot. Is like very large, new home. Do not know if it is a speculative or an owner build ....... but it certainly blocks out what used to be a great view from the road ..... is sooooo big plus has a three car garage within the house, as well. |
Geeze... those prices are criminal...that said, I wish I owned them! :D
The property is fine as it is. No reason to not use the well. They are not gonna order that it be shutdown. It’s just if the septic does fail they might not grant a 3 bedroom size replacement. But they might grant a like for like system. And they might limit the number number of bedrooms/bathrooms more harshly than if it didn’t have this new label if someone wanted to rebuild. It does not change what’s there. But could handicap what could be done in the future. It was just to many maybes and probably’s in the future for the price. |
Just Wait...
Harbor Freight shallow water pumps are marginal. The three I've bought for my Florida place have all "short-cycled", then quit altogether when not used for a few months. If you spend extra for their so-called "warranty", be sure to read this owner's experience: https://www.complaintsboard.com/harb...rranty-c910704 Quote:
Cathedral pines were "harvested". Defective pines were left along the shoreline--certain to be removed in the near future. This creeping "gentrification" will affect Lake Winnipesaukee in many ways; eventually, there will be a lush green lawn with what is effectively a B&B maneuvered to every treeless lot. :( Squam Lake's septic considerations may save that lake from the overdevelopment that winterized retirement homes will bring. |
I can't help but wonder what one septic in one house does to the lake compared to hundreds of boats anchoring in the lake on a given day.
Drawing water from the lake as opposed to a drilled well will maybe be a red flag that makes it impossible for a buyer to get a mortgage on your property? Meanwhile, the City of Laconia has been drawing its' water out of Paugus Bay for over a hundred years, and the Town of Meredith draws its' water from Lake Waukewan, both are natural bodies of lake water as opposed to a drilled well going hundred's of feet into the ground. |
Guidelines today are helping improve all the lakes and water quality. The biggest issues with water quality were caused from many decades ago, not from boats, septics or homes. But from farms (using DDT) and oiling the roads (with PCBs). But build up of homes and roads near the shores are contributing to allowing these contamination to enter the lakes through runoff. Removing the buffers. One other issue today is every time you drop anchor and pull it up, you stir up PCB’s settled in the bottom. |
Put a modest 3 Bedroom home on either for ($400k?) and they would be worth $1.6m+ each, easy (but you'll have the tax bill to go along with it, probably $20K+/yr). Look at the prices of the neighbors. |
We found another place.
180 degrees different than Squam My wife really wanted to be back on NewFound lake. It’s almost 2 acres ~300 ft of water frontage (Sandy, gradual and crystal clear) 3 moorings 1 dock room for two boats Huge house built in 2000 3 cottages (1 year round with full foundation) and all updated in 2000-ish All well maintained. It does not get a mountain Sunset but will get sun on the beach until about 30 minutes before Sunset I think through mid September. That’s a lot more than we had before. Should get a nice sun rise. Taxes are bit high All 4 have been being rented for a few years bringing in $58k/year Only catch is Road is between cottages/house and water front. Even though it was well maintained there is tons of room for improvements. Landscaping and painting. Cottages are on their own state approved septic and the house is on its own state approved septic. Both on public water. Septic capacity is 4000 gal/day (squam was 125) |
Jacuzzi: Second Thumbs Up...
Grammar alert on above: hold off on ALL apostrophe use, and stay mostly correct. |
Back to Newfound Lake?
Rentals aren't the panacea to paying, what?, $35,000 in property taxes. :eek: Deductions aren't what they were in 2015. Considering the roadway, is it a quiet dead-end road? Dirt roads can be dusty--a consideration if you're downwind from the prevailing breeze. Ask around. My last realtor was a serious fisherman, and got the prevailing winds question correct. Construction can tear up a roadway for three years for each built "mansion". Sunrises here are commendable, if you're up to see them! :laugh: |
Road is paved. I know about dust. Been on this lake for 34 years. My wife has been on it since she was born, as well as her mother since she was born. I might sell off half the property with the big house and replace the cottages with a custom home. Not sure what we will do, lots of options. Gotta pay the taxes whether I rent or not. And they are $18k. ~$2k more than I was paying. This property just so happens to be renting and have lots of options. |
| All times are GMT -4. The time now is 05:53 PM. |
