08-31-2009, 09:35 AM | #1 |
speedometer vs. GPS
Has anyone noticed a big gap between your boat speedometer and a GPS? I've noticed as much as a 10mph difference and was wondering which was more accurate? I am assuming the GPS since it is accurate on the road. It is an auto GPS (Nuvi 350) with the Garmin winnepesaukee map on it. Looking forward to hearing if anyone else has noticed this.
08-31-2009, 09:48 AM | #2 |
GPS - as accurate as you will get
I'm amazed how accurate my boat speedometer is. It is usually within a MPH or two of the GPS reading. You can assume the GPS is very accurate, although it may have short glitches if the signal is weak.
-lg |
08-31-2009, 10:28 AM | #3 |
A GPS calculates speed by change of position over the time between position readings. Theoretically if in the time between readings I went like a bat out of hell and turned around and returned to my starting position the GPS would report my speed as zero since I hadn't moved. The point is that the GPS is making some assumptions to calculate speed.
First is that the GPS has no way to know how you got from point to point. It assumes a straight line but you may have been traveling in a curve. The faster you are going the more distance you travel in a sampling period and the more it would effect the difference between a straight line and a curved path. If you are traveling in a straight line the accuracy is going to be higher. BTW, curved paths would result in lower speed calculated than reality. Next, how accurate is your GPS positioning. Since speed is calculated by position and the sampling periods are relatively short, if the positions are accurate the speed calculation will be as well. Accuracy is a attribute of the design of the unit, the installation on your boat (antenna position, etc) and the ability to receive accurate satellite signals from minute to minute. There can be a lot of variability. |
08-31-2009, 11:54 AM | #4 | |
Not so fast there
You're partially correct, I believe a lot of GPS receivers use position differences over time as 1 input to the filtering used to calculate and smooth speed. But the most accurate input is averaged velocities calculated from the Doppler shift of the carrier signals from the satellites. Measurement of the frequency difference is very accurate and knowing about where you are on the Earth and where the satellite(s) are going you can calculate which portion of the velocity vector lies on the Earth's surface and hence your speed. Somewhere on one of my PCs I have a good paper that describes this understandable terms ... alas it isn't on this one.
08-31-2009, 01:14 PM | #5 | |
Most GPS units are doing several samples per minute, so even if you were traveling a non-linear route the speed calculation would still be accurate enough for anything other than a boat doing continuous donuts in a small area.
[insert witty phrase here] |
08-31-2009, 10:16 AM | #6 | |
As an fyi,... My boat speedometer get progressively more inaccurate as I go faster. Between 10 and 20 mph my speedo is relatively accurate, but when I speed up to say 50 mph on my GPS, my speedometer on the boat reads 55 mph. Dan |
08-31-2009, 10:19 AM | #7 | |
What I noticed is when the boat is reading 35mph, the GPS is reading 45mph. Last thing I want to do is get pulled over for the "law that shall not be named" |
08-31-2009, 01:27 PM | #8 |
So what would happen if you were going 55 (which you thought was 45 due to your faulty speedo) and you got a ticket. How can you know your actual speed if your speedometer is that far off? I know one thing...I would be taking that one to court to let the judge decide. As far as I know, GPS is not required equipment...
Getting ready for winter! |
08-31-2009, 02:24 PM | #9 |
Surprised
I was surprised how accurate my 23 year old VDO guages and pitot were when I took the GPS in the boat. 1-2 MPH difference all through the speed range max.
08-31-2009, 02:47 PM | #10 | |
Speed...
08-31-2009, 02:57 PM | #11 |
keeping stock pitot is the key, on my old speedboat the oringinal pitot was within 2 mph of the GPS, the bracket broke and the new one that replaces it was off by 5-7 mph, not sure if the pcikup was longer on the old one or shorter. On my toon it's off by a consistent 5 mph at just about all speeds.
08-31-2009, 03:40 PM | #12 | |
It should be fairly clear by now that the reality is you're not likely to find yourself in this scenario. You would pretty much have to be traveling near the speed of light before you are going to get a speed limit ticket.
08-31-2009, 04:18 PM | #13 |
0.1 mph
My Garmin GPS steady state speed accuracy is 0.05 meters/sec or 0.1 mph. Position data is updated once per second. I might accept the GPS reading over the speedo.
While there are position errors in GPS, those errors change slow relative to the once per second update rate so distance traveled in one second is very accurate. |
08-31-2009, 05:59 PM | #14 |
I have bought 2 "paddle-wheel" speedometers for 2 different boats. The packages included directions on how to accurise them. Basically you needed a measured distance so you could "clock" the boat and adjust the gear accordingly. There is probably a similiar requirement for "pitot tube" versions.
I doubt most factory boats have this procedure performed on them. Speed precision apparently was not considerred that critical since speedo/GPS discrepancy is occasionally discussed on other boat forums I visit. If you want to accurise your instrument it is simpler to use a GPS than a measured course. During a calm period (no wind or chop) operate your boat at various speeds on a lake or large pond. Compare the readings. Adjust your speedo according to the directions. Repeat the procedure until you are comfortable with the results. If you don't have, and cannot get, directions for your version examine the back of it for calibration access. Make a note of the current settings if possible. Then expiriment to see what makes it show higher or lower. If you are not comfortable working on these systems then make a mental note or written table of the discrepancy at various speeds. That's all I think I know about that. Good luck! |
06-03-2010, 07:50 AM | #15 |
LEO article
I was reading an article posted in 'Heloise' the other day. A LEO from Texas says to never use the GPS as a spedometer as it is inaccurate????
He claims to be pulling people over who says: 'Officer, My GPS says I am going the speed limit!' They were traveling over the speed limit. He hinted on Heloise that people should not use their GPS as a speedometer as they are inaccurate. As stated in this thread I find the boat's speedometer readings off from my GPS reading. I am planning on using GPS to keep within the speed limit on the lake. I have observed my GPS as 'dead on' with the speedometer readings in my truck. I also heard that stored data in GPS is being used as evidence in court cases. Should I be confused?????
06-03-2010, 08:02 AM | #16 | |
As far as GPS being used as evidence in court cases, I have not heard of this, but who knows, in this day and age of "big brother" looking at everything we do I wouldn't doubt it. I have heard of On Star being used in court cases however. Dan |
OCDACTIVE (06-03-2010) |
06-03-2010, 09:09 AM | #17 |
ishoot308, great explaination of the gps speed. I have seen in many situations that in a slight turn it will actually show a greater speed then the true speed. This is why when racers are trying to break speed records they have to complete two passes to ensure accuracy.
My gps speedo needs a new battery, but livorsi wants $200 to do the replacment. However, there is no law that I have to have a speedo on the boat. So frankly I don't know how fast or slow I am going. Would be very hard to make that stick in court.
Have you had your Vessel Inspected Yet? |
06-03-2010, 10:28 AM | #18 |
On Saturday, I tested mine out. The speedo is accurate up to around 45 to almost 50, then it goes my way
I will be testing the Garmin against the Tom Tom next weekend. As of now, the best GPS I have in my boat is the iPhone, with a $9.95 Navionics East app in it. I can see everything better, including the marker buoys, than with the Garmin 440. Interestingly, I have the optional $200 card in the Garmin. |
06-03-2010, 10:32 AM | #19 |
$200? Depending on the model, that is like 70-80% of the price when new. You should bring it by, my guess is the battery could be replaced for about $10.
06-03-2010, 10:56 AM | #20 | |
But frankly, I don't care what speed I am at. I am driving safe and prudent. Until there is a law that says I have to have a speedo it really doesn't matter.
06-03-2010, 11:27 AM | #21 |
I put a portable GPS in my boat for a weekend and wrote down the tachometer revolutions for particular speeds.
My pitot tube kicks up over 60 on Lake Winnisquam.. |
06-03-2010, 12:42 PM | #22 |
My speedometer sucks. It doesn't even read until about 25 MPH and then when it does, it's off by 10MPH when compared to my GPS.
However, my boat tops out at 48.5MPH according to my GPS, and that's on flat water with only two people. I don't see a ticket in my future anytime soon |
06-04-2010, 05:15 AM | #23 | |||
There's that "Responsibility" word again...
The same source continues: Quote:
06-04-2010, 07:17 AM | #24 | |
I am not being ignorant of the law, as I am perfectly aware that there is a speed limit. Without a speedometer, I might be ignorant of my exact speed however.
The Following 3 Users Say Thank You to chipj29 For This Useful Post: | ||
06-04-2010, 10:11 AM | #25 | |
Yeah tell it to the judge!
06-04-2010, 11:13 AM | #26 | |
Are speedometers required equipment in cars?
06-04-2010, 11:25 AM | #27 |
Boat Speed
Seems like if you don't have a clue how fast you are going....maybe you shouldn't be behind the helm.
If you want to captain a vessel, you should be ready to accept responsibility for all aspects of the operation of said vessel. Short of that, keep your boat tied up to the dock. That will help make the lake safer for the rest of us. |
The Following User Says Thank You to Happy Gourmand For This Useful Post: | ||
brk-lnt (06-04-2010) |
06-04-2010, 11:54 AM | #28 | |
As an example going at cruising speed on a flat windless day at 3000 rpms feels slow (in my boat at least) You change that into a strong head wind with 2 - 3 foot chop it feels like warp speed. It is all relative. However, you may actually be going slower. As long as you are traveling at a safe and prudent speed for the conditions the # is arbitrary.
06-04-2010, 12:04 PM | #29 |
Be careful what you complain about!
Of course if enough folks complain that is is wrong to have a speed limit but not require speedometers on boats, some intrepid legislator will listen and file legislation to require speed measurement devices on boats travelling on waters with limits.
And then some of those same folks will complain about "nanny state" and "ridiculous legislation". And this, my friends, is a perfect example of how we get all these rules and regulations that we are all (most of us anyway, myself included) so fond of complaining about! |
06-04-2010, 12:09 PM | #30 | |
06-04-2010, 02:51 PM | #31 | |
Aye!
06-07-2010, 02:57 PM | #32 | |
I'd expect there's a limit
08-31-2009, 10:22 AM | #33 |
My Faria speedometer/Bravo 3 leg pitot is pretty darn accurate, according to my GPS. It's only off at speeds below 15 and above 45 or so, and then only by about 1.5 MPH at WOT.
06-04-2010, 06:32 PM | #34 |
what about bumps
We use the GPS on our sleds. My wife has noticed many a time when traveling across a lake at 90-100mph that if she hits a bump the gps will jump up to as much as 150mph.
I’m not sure if this is due to the higher rate of speed or what but she has never commented on it happening when using it on her boat which reaches speeds of 50, or on my baja which gps’s at 66. |
The Following User Says Thank You to Belmont Resident For This Useful Post: | ||
OCDACTIVE (06-04-2010) |
06-04-2010, 09:29 PM | #35 |
Required equipment?
I do not see where a speedometer is required in a car, nor do I see it as required in a boat.
If it was required in a car, I would expect that it would be part of our vehicle safety inspection. While not required in a car, I would not really want to stand before a judge and say my speedometer cable (I have a really old car) broke three months ago, so I really didn't know I was doing 70 in a 55 (my really old car is a big old beast that rides like a dream). I think that once the Judge stops laughing at me(like this ), I would be reaching for my checkbook to pay the fine. Judge would then thank me for making his day. I think that if any of us get a speeding ticket on the lake, and our defense is that we have no means of telling our speed, the Judge may again thank us for making his day (that being right after letting us know just what the fine would be). Bottom line is we have a speed limit, like it or not, and some of us will find ourselves in a position of being caught exceeding the limit (just as we may on our roadways), and when we do, we may very well have to pony up the bucks. We may be able to challenge "radar" qualifications, but the lack of a speedometer would not be a defense, at least in my humble opinion. Regardless, go out and enjoy the lake, and if you see the Upthesaukee as you fly by me, please do give me a wave...I do wave back! Enjoy your summer.
06-04-2010, 10:27 PM | #36 |
Nothing to worry about
the laws have been passed, no doubt about that. But the State gutted the MP budget, which had already been gutted. Let them feel good about what they've done, and don't worry so much about some silly measuring device.
I don;t really care though. Heck, I joined this forum to talk about sailing |
06-07-2010, 03:49 PM | #37 |
whats next?
I know of 4 boaters who have gone up to between 38 and 48 foot cruisers after selling their performance boats.
We are a 2 boat family and always have been. I'm selling my 25 Baja and we are looking to upgrade to a cruiser. We don't need one but if we are going to boat on this lake we are going to be comfortable doing so. Even in my wife’s 26 foot Chaparral you get banged around on any weekend. My Baja is great but I'm not going to waste my money if I cannot enjoy it to its full potential. So we are looking to buy a boat we probably would not have but because of the new speed limit we will. So all the boaters complaining about all the big waves, well it is only gonna get worse. Blame the speed limit. Oh and what about shore line erosion? |
06-07-2010, 04:57 PM | #38 | |
The Following 2 Users Say Thank You to lawn psycho For This Useful Post: | ||
BroadHopper (06-07-2010), OCDACTIVE (06-07-2010) |
06-07-2010, 05:02 PM | #39 | |
06-08-2010, 05:33 PM | #40 |
does not matter
It's just much more economical to become a one boat family. The lake isn't so bad now but when it picks up to its original level prior to this recession even in the 25 outlaw there are days when I just wish I was in a wake maker instead of on the receiving end.
I know that at one time those proposing the speed limit were also boasting they were going to go after the big cruisers next but I just do not see that getting any support. Just look at how many big boats there are and many do not even leave their slip. Guess we will have to wait and see. Someone said to me recently "don't worry eventually these people pushing the unnecessary laws just die off" Wish Pilliod would. |
OCDACTIVE (06-08-2010) |
06-08-2010, 06:21 PM | #41 |
I don't think wishing for a politicians death is warranted, if fact it's disturbing. I wish for these boneheads to be tossed out of office, but wishing for their death lowers you to their level.
In our system, we elect a few mistakes, you just have to wait them out. It's what seperates us from the crazies. |
06-09-2010, 01:02 PM | #42 | |
I agree, except we only have to wait them out about another 6 months and the political landscape could be extremely different then what we see today.
06-09-2010, 03:10 PM | #43 |
one can hope....
From your mouth (err...fingers?) to God's ears (err...eyes?)....
06-09-2010, 03:19 PM | #44 |
Hey come on now... I didn't say it, just helping a friend out.. LOL
06-09-2010, 03:58 PM | #45 |
sorry, I just took Belmont a little too literally. I just flashed back to all the "Kill B#sh" signs.
06-10-2010, 05:35 PM | #46 |
sorry
I did not mean literally. Unfortunately the town of Belmont has a lot of shortcomings and he is one of them. Over the years I’ve learned that not many of the elected officials in the town Belmont have much backbone. Years ago we went thru a subdivision and found this out first hand. Also had problems with a neighbor and that’s where it really became clear.
I honestly thought they needed to consult someone else before wiping their #$%%. To bad, we have a great piece of property but will probably elect to build our new home elsewhere in the area. |
02-15-2011, 07:08 AM | #47 |
06-11-2010, 03:32 AM | #48 | |
A Little Help With the Math, Please...
NH Legislators grabbed $700K from the MP budget, but had earlier approved a near-doubling of 2010 boat-registration fees: even if registration fees only produced $12 for each registered boat—as a very conservative example—there are over 90,000 boats that can be expected to register! (So over $1 Million would have been collected—leaving a net gain in MP funding). |
06-11-2010, 06:28 AM | #49 |
APS, I had read a statement detailing the MP budget. Let me see if my old mind can remember the gist of it.
Apparently, they had a fund that was growing a little bit for a rainy day. The annual budgets, combined with decreasing registrations, had slowly eroded the fund. In addition, costs have steadily risen. The MP has had cutbacks and a decline in personnel as a result. So while they have doubled the fees, they have effectively taken that amount out of the equation. $3 million budget, less half funded by CG. $1.5 million is the balance, which has been subsidized by the fund balance, which was in decline. They take $700,000, roughly half. So nope, not an increase. The registration increase was supported because of the MP's statement that costs were outstripping their funds. The Legislature had increased their costs, so it was only fair. In the end, the registration increase became a general fund tax that boater's pay. The MP loses, at least this year. |
02-14-2011, 09:16 PM | #50 |
Ticket on 89
I was driving the ol' Jeep down 89 from Burlington VT Friday. It was fairly straight stretch in Andover, NH. With the cruise control set at 74 on my Garmin NUVI 225, the Jeep speedometer says 77,78 mph. Local Andover cruiser stopped me and clocked me at 82 mph! So the GPS was off 8 mph!
Garmin claims .1 mph accuracy. I was traveling in a straight line. I'm wondering if the radar could be inaccurate. It was an one of those dashboard mounted units and he was parked in the median. I wonder how they check the accuracy of police radar as I am sceptical of an 8 mph difference. How would you know if the LEO is telling the truth?
02-14-2011, 11:23 PM | #51 | |
Last Time I Traveled I-89...
Should you go to court to fight the ticket, don't tell the Judge what you just told us... Wise... Good luck...
02-15-2011, 09:50 AM | #52 | |
Buy a radar detector. It stops you from casually driving along and getting a needless ticket. |
02-15-2011, 08:13 PM | #53 |
Radar, both dash mounted and handheld, are supposed to be calibrated by a TMDE company once per year. We have a company come out and do it officially. We are also supposed to check the calibration with tuning forks often. You strike the tuning fork and the vibration simulates pre-determined speeds (for us it is 35 mph and 65 mph, we have two forks) there should be a stamp or sticker on each radar and the dept should be able to provide proof of date and time of calibration. This may not be possible at the initial hearing but there may be an appeal process to a judge (this is the case in Mass). Its a shot in the dark but if plan a doesn't work (officer doesn't show up) maybe plan b will work (out of calibration). If both fail, throwing yourself at the mercy of the court will sometimes work if your driving record is otherwise flawless and you are respectful...and the stars line up...
Good luck with the radar detector angle... I will put my radar skills against your detector any day of the week (playfully ofcourse). I have never given a break to a speeder that has a radar detector on the dash.... Secret- radar isnt sending out waves until I see you and push the button. Once that happens- BAM! your speeding and your caught (unless you can bleed 10+ mph in a milisecond or I blink,lol) Good luck on the ticket HCG |
The Following User Says Thank You to hancoveguy For This Useful Post: | ||
RailroadJoe (02-16-2011) |
02-15-2011, 10:39 PM | #55 | |
As with any radar or lasar, if you are the only car on the road then you're vulnerable to getting a ticket if you're speeding. Also, if I was to get pulled over my detector would be out of site from your view and mine also has VG-2 immunity Some of us are serious tech geeks |
02-16-2011, 05:15 AM | #56 |
Most of you are just speeders who tailgate and will someday end up in an accident. Don't know why people are in such a hurry to get places.
02-16-2011, 08:14 AM | #57 | |
Radar detectors are popular gadgets among speedsters who derive thrill from bending the rules and eluding the radar guns of the police. Some people are not satisfied with moderate speed while driving. They want to be the fastest driver on the road as well as get to the places they're going in record time; they want to be always in the race. IMHO anyone that has radar detection equipment in their vehicle and gets into an accident that can be attributed to high speed should be penalized the same as someone who Drives Under the Influence (DUI). Here are some of the states that deem radar detectors illegal: 1. The usage of radar detectors are prohibited in the Commonwealth of Virginia. They have laws banning the use of radar detectors. Not only are radar detectors illegal to use in Virginia, they are also illegal to have in the vehicle. 2. Radar detectors and radar jammers are illegal in the District of Columbia. The passing of their laws to ban the use of radar detectors was set in 1995. 3. In Illinois, radar detectors are only regulated in commercial vehicles of over 26,001 pounds. 4. On US military bases, they are legal to have but illegal to use. 5. Radar jammers are illegal in the states of Utah, California, Oklahoma, Colorado and Nebraska. 6. Radar detectors are not specifically regulated, but things hanging from windshields are not permitted in the state of Minnesota. 7. For motor vehicles over 18,000 pounds and any other commercial motor vehicles over 10,000 pounds in New York, radar detectors are illegal. |
02-16-2011, 09:50 AM | #58 | |
Use of a radar detector to a DUI? Hint: Look at how many cars on the road have radar detectors. The rules aren't bent. Speed and you can still get a ticket. You also don't elude radar. The detector simply tells you that radar (or lasar) is present. If you are the only car on the road, the detector may be a ticket indicator..... And by the way, I haven't looked into radar jamming in detail but even if that act was not illegal, the jamming transmitter would in all likelihood be illegal via the FCC. Again, I haven't researched it but I'm betting that jamming is illegal because of something other than a state law. |
02-16-2011, 09:38 AM | #59 | |
I don't have to drive that much anymore but I have in the past been a long distance commuter. Trust me when I tell you that the odds of the day you drift up in speed to 75-80 MPH it's nice to have a radar detector bleep at you so you avoid the stray ticket. It's not some extreme desire to play race car driver. I can assure you some many of the lakes region long distance commuters who may read this will understand how easy it is to have a speed zone change and bam, ticket. And the states LOVE speeding as they generate revenue out the fines they collect and the cops use it as a way to justify their expenses. Without speeding tickets your police departments would probably have less officers and less equipment. You should thank them |
02-16-2011, 09:49 AM | #60 |
It seems there are a lot of cars being towed that have extensive front end damage. Tailgating ? Or just not paying attention.
02-16-2011, 09:57 AM | #61 |
The Following 2 Users Say Thank You to Rusty For This Useful Post: | ||
camp guy (02-18-2011), RailroadJoe (02-16-2011) |
02-17-2011, 10:03 AM | #62 | |
Just a reminder...my professional estimation of your speed is more than enough to hold you to a ticket. If I point my radar/lidar at you and nothing shows up, and I "estimate" that you were traveling in excess of a posted speed limit, that is good enough to ticket you. Tried and true, this is established precedent in Ohio and has been adopted by many other states including Massachusetts (not sure about NH but they are usually ahead of us when it comes to pro-police law)
http://www.cleveland.com/open/index....l_estimat.html With this in mind...I don't hate speeders enough to need this. Just an interesting factoid. Good luck, btw, the good guys always win...eventually! HCG Probably be another very long thread as to which one of us is wearing the white hat...lol Quote:
02-17-2011, 01:38 PM | #63 | |
I am shocked that the court did not just toss the case if the guy was not certified using radar. I also believe this is an overzealous enforcement and the state makes sure they don't lose these cases or they risk losing all that revenue. And, that decision was not unamimous. I'd like to see a US supreme court ruling on this case. If you think this is good for society for judges to give carte blanc discretion to an officer to guess a vehicle speed to issue a speeding ticket then I give you no credibility. Luckily this is probably rare and if an officer used this more than once I think it would raise flags about why he's not using the state supplied equipment. There are checks and balances. Just goes to show the speed limits are not about safety but revenue. Makes me smile even more knowing the stuff I have in my truck. Gives power back to the people |
02-17-2011, 02:16 PM | #64 | |
02-17-2011, 07:06 PM | #65 |
The case alludes to this being valid only if the officer is trained and certified in estimation. This is a substantial instructional block in every academy that I know of in Mass. This estimation principle, if you will, is mostly used in an unforseeable scenerio. You will not find officers setting up on a stationary traffic enforcement assignement armed only with their estimation skills. The prime example of how this is used-
You are on patrol in your cruiser. You are stopped, waiting to pull out from a sidestreet or strip mall or something like that. Your dashmounted radar is facing straight forward and straight back (perpendicular to the traffic flow) so it is useless on short (immediate) notice. You have no handheld with you. Now, you have travelled this road hourly for most of your adult life and you know and are comfortable with what the traffic flow looks like at any given hour. Just then, from around a distant corner, you see a smaller car headed towards you. Based on all your experience and training (nevermind as a police officer, just as an alert motorist) you know beyond all reasonable doubt in your mind that this vehicle is travelling well in excess of the posted speed limit of X. This vehicle is travelling so fast that you believe it could eventually become a hazard to other motorists but not so fast that it is out of control. What do you do? A. Nothing, because you didnt get it on radar or laser and you clearly do not have enough to stop the vehicle on any foolish reckless driving violaions (which there is no such thing btw) B. Unlawfully stop the vehicle and only verbally chastise the operator C. "estimate" the vehicle's speed based on your inherent knowledge of the road and the traffic flow and cite the individual accordingly, knowing that even though you don't have 100% assurance of your estimation's accuracy but in the name of the public good, you are bound to "act" in some way. D. shoot the person and go get coffee and donuts This is truly not meant to provoke an argument but rather to illustrate the necessity of the law/policy. You are certainly entitled to your opinion, but this is reasonable in mine. Disclaimer- As many of you know from my previous posts, I am not a big speed enforcement guy (or state revenue agent as it were) as this practice would make me a hypocrite, but there are some times when you just need to trust the system. BTW- Lawn psycho, you are off track if you think the liberal courts in Mass give two flying hoots about revenue when it comes to tickets, appeals, or anything else within their judicial scope. I have seen sooooo many fines just eliminated for no good reason. They truly do not factor governmental revenue into justice. They are far more likely to find on behalf of the violator just to spite the police. |
02-17-2011, 07:39 PM | #66 | |
"4511.20 Operation in willful or wanton disregard of the safety of persons or property. (A) No person shall operate a vehicle, trackless trolley, or streetcar on any street or highway in willful or wanton disregard of the safety of persons or property. (B) Except as otherwise provided in this division, whoever violates this section is guilty of a minor misdemeanor. If, within one year of the offense, the offender previously has been convicted of or pleaded guilty to one predicate motor vehicle or traffic offense, whoever violates this section is guilty of a misdemeanor of the fourth degree. If, within one year of the offense, the offender previously has been convicted of two or more predicate motor vehicle or traffic offenses, whoever violates this section is guilty of a misdemeanor of the third degree. Effective Date: 01-01-2004" |
02-16-2011, 11:38 AM | #67 | |
As far as my Garmin GPS (Nuvi 2xx series), it seems to match quite well to my speedometer in all my vehicles. But I also run OEM tires. Does your vehicle has the STOCK tire sizes and STOCK rear gears? Change either one of those and your speedometer (or speed sensor gear) will require changing. Changing from say a 255 to a 265 tires and or vice versa and you can get a different reading. There's converter tables out there to tell you the different speedometer readings. Changing to a smaller tire is a cheating way to get more gearing in your rear-end (well, your vehicles anyway)...... |
02-18-2011, 03:23 PM | #68 |
I agree wholeheartedly with Dan & Rusty.
Hancoveguy has been a very thoughtful poster that has shared many of his experiences and expertise in a variety of posts....posts that, to me, make this site worth perusing everyday. Don't let a differing opinion or bias against law enforcement chase you away. That has happened all to often on here over the years I've been involved. I have seen several NHMP personnel and other law enforcement types come aboard, try to explain the law, only to be chased away over time by a very small percentage of the members here. It is too bad, especially in the case of both a retired and an active NHMP officer that posted here in the past. The great majority of us lose a tremendous resource because of the actions of but a few that made them decide the foolishness wasn't worth the effort. Don't get me wrong. Just as in any profession there are always a few rotten apples and plenty of stories of horror amongst the public that may have had a negative experience in the past. But to personalize this angst against a fellow poster who has no connections to far ago alleged incidents is not fair to that poster, nor the rest of us that may lose a valuable resource in the end. Hang in their Hancoveguy...we need more posters like you, not less! |
The Following 2 Users Say Thank You to Skip For This Useful Post: | ||
hancoveguy (02-21-2011), Rusty (02-18-2011) |
