Old 06-14-2023, 05:47 PM   #1
LakeSummerFun
Default Washing Machine Repair
My parents on E. Bear Island have a GE washing machine that doesn't work. Can anyone recommend someone who can come out to the island and fix it?
Thank you for any suggestions.
LakeSummerFun is offline   Reply With Quote
Old 06-14-2023, 08:42 PM   #2
TheTimeTraveler
Not sure how old their machine is but it could in fact end up being cheaper to just replace the broken machine with a new one.
LakeSummerFun (06-16-2023)
Old 06-15-2023, 06:31 AM   #3
steve-on-mark
steve-on-mark's Avatar
you could try contacting Andrew with Accurate Appliance...he's awesome and honest!
The Following User Says Thank You to steve-on-mark For This Useful Post:
Old 06-15-2023, 10:00 AM   #4
songkrai
Having had washing machines repaired multiple times over decades.
Yes, it would be better just to get a new one.
$489.00 Best Buy
Amana top load washing machine.
LINK
Skip the foreign brands. Skip GE/Hotpoint - now owned by Chinese/Korea company.
If you plan to live/stay a very long time then get a Speed Queen - the traditional model.
The Following User Says Thank You to songkrai For This Useful Post:
Old 06-15-2023, 10:18 AM   #5
Explain "doesn't work." Especially with older washing machines, the problem can be something very simple to fix, such as a worn, loose, or broken drive belt, or perhaps a failed water valve. It may be faster and far cheaper to fix as a DIY project, given the wealth of good advice available here on the forum.
Old 06-15-2023, 11:47 AM   #6
Lightbulb One Easy Fix...
My late BIL, The Maytag Repairman, always replaced the two belts every season.
'Relatively easy task: Just tip the washer on its side and the task forward will be revealed.
Old 06-16-2023, 07:29 AM   #7
LakeSummerFun
Default Thank you Everyone!
I appreciate the thoughts and suggestions.
Happy Summer to All!
Old 06-16-2023, 09:09 AM   #8
So, just what is the problem with the washer? We're all dying to micromanage the DIY repair via the forum, but we need details.
Old 06-16-2023, 10:59 AM   #9
songkrai
Ya. The average Joe or Jane knows exactly how to change a drive belt. And knows exactly what tension the belt needs.
And has the tools and knowledge how to take apart a washing machine.
And can find a parts list for that model. Then find the part.
And if it is the control panel. Good luck with that one. Half the price of a new machine. And that may not be the entire problem.
Certainly, it can be done.
My propane gas furnace stopped working.
A simple Utube search came up with some solutions. And yes, one of them fixed problem. And furnace has been running fine for 8 more years.
Yes, some folks can fix things.
But the average Joe or Jane may not have the tools or access to parts. If the parts are even available now.
Short answer. Get a new machine.
Old 06-16-2023, 07:31 PM   #10
TheTimeTraveler
The biggest issue involved here is that the original poster is on an island, so you start out of the gate with all sorts of logistic issues just to get the repairman from the mainland to the island.
Once he reaches the island he then has to diagnose what is needed and then order the parts and schedule a second trip (assuming he is unable to make the repair "on the spot").
When you work all these things into the equation then it may in fact be cheaper to simply replace it rather than throwing money at a used machine which could be on its last legs anyways.
Labor costs aren't cheap, and two trips to an island location could very well justify a simple replacement to begin with.
In any event, if you do buy a new machine then be sure to purchase the extended warranty. Living on an island it will certainly pay for itself should you have future issues.
Best of luck!
Old 06-20-2023, 06:45 AM   #11
TheProfessor
Wonder how an extended warranty works on an island property.
Old 07-04-2023, 07:47 PM   #12
Default Bad luck thread!
Well after 15 year of service our Kenmore washer broke today! Something grinding with the agitator. I lasted about 10 minutes with my repairman’s hat on and decided that after 15 years we are just going to simply replace it. Of course my wife then said we might as well replace the dryer too because it’s 15 years old as well!! So it looks like a call to Baron’s in the morning to see if they have any Speed Queens in stock….what’s the chance they will install it as well??
Island living at its best!!
Old 07-04-2023, 08:48 PM   #13
TheTimeTraveler
Here is their website that you can check out their stock offerings:
www.BaronsMajorBrands.com
Hopefully they have the machine and color you're looking for.....
Old 07-05-2023, 04:14 AM   #14
Check with someone because a repairman who had recommended Speed Queen to me as the only one to buy said that they are not longer that much better -as they used to be. I think he said they were sold.
Old 07-05-2023, 05:36 AM   #15
Soooo, as part of my research when buying our washer a couple years ago, I discovered that Speed Queen was getting a bad rap for the newest series of their machines (TR models), which were designed for efficiency and to meet water use guidelines.
What they did, however, is bring back the "classic" TC5 with an "eco" mode that met the water guidelines while every other mode is what their original machine offered.
We have it, and it's awesome—huge loads done in 35 minutes! And, maybe because we replaced an older machine, we never noticed any water use difference (and use cold for everything).
So, Dan, if you're looking for the classically-built Speed Queen, you'll be looking for the TC5. It still uses a digital panel rather than analogue knobs, but the machine itself is the bulletproof one SQ built its reputation on.
https://speedqueen.com/speed-queens-...-your-laundry/
TheTimeTraveler (07-05-2023)
Old 07-05-2023, 06:11 AM   #16
Default Tc-5
Think,
The TC-5 is the one we are looking at and is in stock. It does use knobs and has no digital readout panel that I can see and that is what we want. Also has no locking cover which is another feature my wife wants.
Thanks!
Old 07-05-2023, 06:37 AM   #17
Oh thanks so much for that, it's good to know. So if anybody does decide on the SQ we just need to be careful of the model. Yup, no surprise government regulations mess everything up. They think they are saving us from the world or the world from us and it ends up a bigger mess.
Old 07-05-2023, 06:58 AM   #18
Think,
Thanks!
I probably should've been more clear about the panel: it has knobs to adjust cycles, etc. but they are digital and have electronic touch buttons for start, deep fill, etc. You can see the black buttons/press pads (middle) in this photo.
I would've loved a completely analog machine, but *sigh* it was not to be.
The machine is an animal, though. Enjoy!
Old 07-05-2023, 08:39 AM   #19
Thanks Think!
That makes sense….
Just talked to Barons and we have new appliances being delivered to Glendale Docks on Saturday. They will not deliver or install on islands.
This page was generated in 0.75844 seconds
